New pictures don’t show any labels [FIXED]
B.Douille
Post by B.Douille »
In the main view, when new pictures are added, the label stays blank even after a manual refresh.
It happens whatever it's from the camera, a screenshot. It happens as well when a picture is moved from an album to another. The same happens whatever in the Gallery or the Storage browsing mode.
However, the data (EXIF:Modified, EXIF:Taken, File:Modified) are well shown in the details view of the images.
A restart of the App’ temporary fixes the problem.
I just installed* the last version as from 04/07 and the problem still.
Thank's Pierre for this new application :)
*Cleared autorisations, cleaned storage, uninstalled previous beta, installed new one.
Daniel, happy user for 20 years, to manage photo and videos and share them in slideshows (Windows 11, Linux Ubuntu and Android)
B.Douille
Re: New pictures don’t show any labels
Post by B.Douille »
Update. This bug influence the sorting by date/time, both in Gallery and in storage view. This looks like the data source used to sort is the same as for the labels. Any picture modified by app for example doesn't show the date/time labels so the sorting process defaults to the file:created. See samples (all files are named with a timestamp)
Folder view: Modified files looks the more recent in the list.
Gallery view. Note some files are well positioned:
The difference between Storage and Gallery is explained by the fact file:created is different. Real value in the case of folder mode :
It comes from EXIF date in case of Gallery mode :
An Android feature or a Samsung feature (but Google Photos shows the same as Samsung Gallery) ?
Please note also the GPS icon disappeared on those modified pictures whereas the GPS latitude/longitude values have been preserved (altitude was lost during modification)
B.Douille
Post by B.Douille »
Fixed :)
Using version 1.0 16/07 I checked labels for new pictures and screenshots, files renamed, files moved. I checked also wrong sorting and GPS icon missing for pictures modified by Samsung Gallery app.
Thank you Pierre
