1.11.5 XnView MP Viewer ratings in wrong position
XnView: MP 1.11.5 - 64 bit
OS: Windows 11
All image ratings in viewer mode display on the upper right of the screen instead on the left. Have fully uninstalled and deleted settings folders, reinstalled previous versions but bug persists.
Dr.Mood
Re: 1.11.5 XnView MP Viewer ratings in wrong position
Rating is always shown in top-right corner (top-left if info is in top-right)
Dr.Mood
Could there be there is an issue in my settings? I have XnView MP installed on 3 laptops and my ratings have always shown on the Left in Viewer Mode prior to the update. Info only shows for me in full screen mode and doesn't seem to effect the ratings placement in Viewer Mode. Is this an issue in my configuration or a potential bug? I'm afraid to update my other PCs and be unable to fix this.xnview wrote: Mon Jul 06, 2026 5:49 am Rating is always shown in top-right corner (top-left if info is in top-right)
jkm
Fix your settings:
Tools->Settings:View:Info:Position change to Top-Right
right, there was a change. If info is top-left, rating will be top-right. what do you have in Settings>View>Info - Position?
