An issue already noticed in the ShellExt repository: windows explorer crashes when ShellExt is used on a jpegXL file. This seems to be due to a change in libJPEGXL.dll in the MP1.11.5 zip package (replacing it by libPEGXL.dll from the MP1.11.2 zip package solves the issue)
BTW, note that all links to download ZIP packages of all versions (for windows at least) points to the latest version (1.11.5), so it makes hard to download a previous version for testing (fortunately I had a copy of MP1.11.2 zip on a USB key)
cheers
simon
ShellExt issue with libJPEGXL 1.11.5 for windows 11
simon
jkm
simon
Re: ShellExt issue with libJPEGXL 1.11.5 for windows 11
Indeed, thanks.
sheik124
simon wrote: Tue Jul 07, 2026 9:53 am Hello,
cheers
simon
Thank you both. This was the only thing that actually fixed the issue for me, which persisted even in 1.11.6jkm wrote: Tue Jul 07, 2026 10:08 am You can find previous versions here:
https://download.xnview.com/old_versions/
Please download latest packagesimon wrote: Tue Jul 07, 2026 9:53 am An issue already noticed in the ShellExt repository: windows explorer crashes when ShellExt is used on a jpegXL file. This seems to be due to a change in libJPEGXL.dll in the MP1.11.5 zip package (replacing it by libPEGXL.dll from the MP1.11.2 zip package solves the issue)
Kadet
Now all is ok.xnview wrote: Wed Sep 09, 2026 5:28 amPlease download latest packagesimon wrote: Tue Jul 07, 2026 9:53 am An issue already noticed in the ShellExt repository: windows explorer crashes when ShellExt is used on a jpegXL file. This seems to be due to a change in libJPEGXL.dll in the MP1.11.5 zip package (replacing it by libPEGXL.dll from the MP1.11.2 zip package solves the issue)
simon
On my side, no more crashes with the latest version, but no thumbnail shown when using shellEx on a jpeg-xl file (contrarily to what happens with jpeg, tiff or png files)
