Export Metadata to 'XMP-dc:subject' and 'XMP-lr:hierarchicalsubject' automatically?
OnkelTom
Post by OnkelTom »
Hello dear forum members, I just noticed, that during assigning categories, these are automatically :?: :!:
exported to 'xmp-dc:subject' and 'xmp-lr:hierarchicalsubject'.
As far as I remember, I needed to do (could do) this manually with the menu "metadata - update files from database".
Until today, this was my workflow, but now I noticed, that as soon as I assign a category, the xmp-subjects (lr and dc) are instantly created, on most of my JPG's (whereas some JPG's are not showing any XMP data... for which I have not found a reason, so far).
Is that automatic-export a new "feature" I missed or a bug? I could not find any announcement or other reports, regarding this behaviour.
I want to have the option, to export assigned categories as described, but only after I finished assigning (all) categories to all files, not automated, resulting in numerous write-processes. As far as I remember, I have not changed anything in the xnview.ini or my settings.
For reference, you can see my "settings-metadata" and "settings-metadata-sidecar".
Can anybody please give me a hint or advice, please?
Thank you in advance!
Re: Export Metadata to 'XMP-dc:subject' and 'XMP-lr:hierarchicalsubject' automatically?
automatic update was always here, as soon as you change the file selection
OnkelTom
Post by OnkelTom »
Pierre, thanks for your feedback.
I would swear on my mother's life, that it was not for me... :!:
Especially for these two tasks, I modified the toolbar, to have "updating files" and "updating database" always at hand...
Just as a side-note: As I often simultaniously use "ExifToolGui" in the same directory, where I categoriese files, I see XMP-DC, XMP-LR, IPTC data, in parallel or synchronous and still, I would swear on my life, that - at least for me - the automatic update of XMP data in the files was not happening
(which I was happy with).
I cannot tell, if there was a mixed-up setting in some ini-file or whatever changed with one of the recent updates...
I will then just need to adjust my workflow like...
  1. de-activate XMP export
  2. categorise files
  3. re-activate XMP export
  4. update files by "update files from database"
...something like this.
Anyway, I appreciate your time, looking into this and for your feedback.
In my opinion, the efforts you invest into the software are priceless - again, THANK YOU for this fantastic piece of software and the support you and the forum members provide!
