AV1
biley
AV1
Post by biley »
The attached file for example. It was originally a .webm file but I had to rename it as a .mp4 to be able to attach it in this platform.
It plays fine on my system as a .webm or a .mp4 in VLC or version 1.9.2 of xnviewmp, but in the beta of version 1.11.4 I don't get any visuals.
It does print the error messages:
[av1 @ 0x56521052b6c0] Your platform doesn't support hardware accelerated AV1 decoding.
[av1 @ 0x56521052b6c0] Failed to get pixel format.
[av1 @ 0x56521052b6c0] Get current frame error
If that helps.
Re: AV1
Please try this beta
biley
Re: AV1
Post by biley »
Beta 3 has fixed my issue playing AV1 codecs, but there is a regression in Beta 3 for me when playing other video files.
In some videos, the video plays but when I click on the progress bar to jump around in the video (or when the video ends) the program crashes and terminates.
It prints the error message "Segmentation fault (core dumped) ./xnview.sh"
I have attached a clip of a video where this happens.
Re: AV1
biley wrote: Mon Jul 20, 2026 3:10 am Beta 3 has fixed my issue playing AV1 codecs, but there is a regression in Beta 3 for me when playing other video files.
Please try this version
biley
Re: AV1
Post by biley »
[/quote]
[/quote]
Issue appears to be fixed and I haven't noticed any other problems, but I haven't tested extensively.
