Rating/Change timestamp
Could you test these 2 features in last build?
Kadet
Re: Rating/Change timestamp
Star rating works.
I have rated 6 files, but when I select the view menu, Ratings shows the number 3. When I tap Ratings, it shows the correct number of rated files.
Edit: After rating 45 photos from one day as a group one tap, the Rating now shows the number 5.
Changing the date doesn't work. After selecting a new date and/or time and tapping Apply, nothing changes.
rightKadet wrote: Sun Jul 12, 2026 12:24 pm Changing the date doesn't work. After selecting a new date and/or time and tapping Apply, nothing changes.
Change date/Convert/Resize are now here
