1.11.5: Short "Camera Manufacturer" tag problem in TIFF
cabanmichal
Post by cabanmichal »
XnView: MP 1.11.5 - 64 bit
OS: Mac 64bit (Apple Silicon)
When you set the EXIF:Make tag of a TIFF file to value shorter than 4 characters, XnView displays a garbage value for this tag.
Effect: Incorrect value of the Make tag is displayed and it is also preserved in JPG files converted from the affected TIFF files.
  1. Set the EXIF:Make tag to value shorter than 4 characters, e.g. Fed (exiftool -EXIF:Make=Fed file.tif).
  2. View such file in XnView MP.
  3. Observe that "Camera Manufacturer" is not "Fed" but "N" (a garbage value). Exiftool reports correct value, Apple's preview reports correct value, tiffdump reports correct value.
  4. Convert affected TIFF file to a JPG using Batch convert.
  5. This garbage value is present also in created JPG image.
Actual behaviour (bug):
Values of EXIF:Make tag shorter than 4 characters are displayed incorrectly for TIFF files.
Expected behaviour:
Values of EXIF:Make tag (Camera Manufacturer) shorter than 4 characters are displayed correctly for TIFF files.
Re: 1.11.5: Short "Camera Manufacturer" tag problem in TIFF
This problem is supposed to be fixed in XnView MP 1.11.6. Please check and confirm the bug fix here.
