Renaming and sort order
blackxacto
Post by blackxacto »
If I edit the names of all images in a folder to be Photo####. I get all images in numerical order by name only.
If I edit the newly edited folder to Pictures#### the result will change the name, but order may be mixed. I must manually SORT by name.
If I don't remember to SORT by name afterwards, any editing will destroy the order on screen.
Why? Why isn't there a way to fix the order of images in a folder, no matter what I do to the images in a folder.
I wish there was a button to click, LOCKING images positions within the folder, no mater how you edit.
Learning to mind my own business. 8)
jkm
Re: reordering
Post by jkm »
And exactly how are you doing your renaming?
I don't see any such issue when using Batch Rename.
Do you have Settings:File List:"New files are added at the end of the list" enabled?
blackxacto wrote: Sun Jul 12, 2026 11:34 pm If I edit the newly edited folder to Pictures#### the result will change the name, but order may be mixed. I must manually SORT by name.
Clarify this. Are you saying you rename the files a 2nd time, or are you changing the name of the folder itself? If you're changing the name of the folder, exactly how? Changing the folder name by renaming in the Folders pane of XnViewMP does not change the sort order of the folder.
blackxacto
Re: reordering
For Thumbnail viewing:
When I position images in the display in an order I like, I SELECT ALL images in the folder and batch rename: MySort####, which starts the display w image: MySort0001, etc.
The only way I have found to keep a special order in XnView is to keep images within a folder organized as to name+sequential numbers.
If I SELECT ALL anytime afterwards and change the name to NewSort0001, etc. without SORTING BY NAME first, XnView will change the sort order of the images in the folder. The images will now be out of my order, but will have the new sequential names.
I wish there was someway to FIX the display of all images in order, so that I don't have to remember to Sort by name first, which I usually forget, losing the entire sorted collection in the folder. When I view my images within a folder, I want the order to fix, as editing without sorting by name first will always screw up the images display order.
jkm
Re: reordering
Post by jkm »
blackxacto wrote: Mon Jul 13, 2026 1:50 am For Thumbnail viewing:
When I position images in the display in an order I like,....
The only way I have found to keep a special order ...
So you're using Custom Sort? (View->Sort By->Custom)
What version of XnViewMP are you running? Make sure you have 1.11.5
There was a bug that was fixed in 1.11.5 (over 2 weeks ago) that would affect you if you're using custom sort. Batch Rename would not honor the custom sort order. But that was fixed, and it's no longer a problem. You're probably not on the latest version.
Your repeated wishing is unnecessary. The sort order for folders obeys the user's sort by selection. The only issue was files getting resorted alphabetically inside the Batch Rename dialog when Batch Rename was used, and as I said, that's been fixed.
If you'd searched the forums for sort order, or batch rename, or even looked at page 1 of threads, you would have found these posts on this issue:
In 1.11.4, Batch Rename dialog no longer honors Browser sort order
Batch Rename in 1.11.4 doesn't sort like Browser
Hopefully this helps...
blackxacto
Re: reordering
View / Sort by / Name/ All
Tools/Batch Rename/All
XnView-MP: 1.11.5
jkm
Re: Renaming and sort order
Post by jkm »
Good luck with your problem.
Re: reordering
blackxacto wrote: Mon Jul 13, 2026 1:50 am When I position images in the display in an order I like, I SELECT ALL images in the folder and batch rename: MySort####, which starts the display w image: MySort0001, etc.
Please describe a way to reproduce...
blackxacto
It's complex because I am surprised anytime it happens.
It only involves thumbnails in a folder in XnView-MP. Maybe I should not be using XnView-MP to do this, but I have a folder of appx.1500 images.
I normally browse the folder in thumbnails. I want to keep a certain order to the thumbnails so I select all images in folder and rename then one basic name followed by sequential numbers. XnView is fabulous for this.
I cannot figure out how some thumbnails become out of order until it is too late having renamed all images.
This maybe only my problem, I'm just saying I'd like a LOCK that locks all thumbnails in position. They can be edited, but position in folder is locked. And I can unlock whenever I want. Just a request. Don't mean to start any debate,.
