XnView MP's dropdown lists (e.g. combo boxes) and context menus are exposed via macOS Accessibility as AXRole = AXWindow with AXSubrole = AXDialog. Because these are reported as real windows rather than as transient menu/popup elements, third-party window managers that use the Accessibility API to enumerate windows (e.g. yabai) pick them up as regular, manageable windows. This breaks focus_follows_mouse and other window-management behavior, since the WM tries to treat a transient dropdown/context menu as if it were a normal application window.
Expected behavior
Transient popups like dropdowns and context menus should not be exposed as AXWindow/AXDialog. In macOS accessibility terms they should typically be reported as AXMenu/AXMenuItem (for context menus) or as non-activating popup/panel elements that are not flagged as root windows — the same way native Cocoa NSMenu-backed popups behave. This is also how well-behaved Qt apps' native QMenu popups usually appear.
Actual behavior
The dropdown is reported with (yabai -m query --windows):
"role":"AXWindow",
"subrole":"AXDialog",
"root-window":true,
"level":101,
"is-floating":true,
"can-move":true,
