Open RAW data button for embedded preview
golemus
Post by golemus »
There seem to be couple of issues related to viewing RAW images.
- it is hard to know if the image on the screen is preview or rendered RAW data
- there is no simple way to switch between viewing rendered RAW data and preview
One suggestion is that when you have enabled "embedded preview" is that there could be button at corner of display: "Open RAW Data"
It could be in Settings menu like this:
- enable "Open Raw Data" button while viewing RAW-file embedded preview
When you press this button it opens RAW data.
In raw data view there could be possibly "return to embedded preview" button.
Although if half-width RAW image is enabled I am not sure what would be most sensible behaviour.
Re: Open RAW data button for embedded preview
