👍[v.15/07] The filter shows unsupported files [Fixed]
Kadet
At this stage of testing, it may not matter, but for the sake of formality, I would like to inform you that after setting any file filter, I can still see JXL and BMP files that the application does not yet support.
Re: [v.15/07] The filter shows unsupported files
when using which source? no thumbnail or labels?Kadet wrote: Wed Jul 15, 2026 7:22 pm I can still see JXL and BMP files that the application does not yet support.
Kadet
When I look at the Gallery or any folder and, for example, I gives a filter for PNG files, I also see JXL and BMP files (I don't have any other types beyond the basic files).
After today's update, I can now see the BMP thumbnail and all the data on the label, and after tapping I can also see the image and additional information. For JXL I don't see a thumbnail and only information about the date, file name and size. After tapping I see the image, but still without the X/Y size and EXIF information.
ok, but do you have alwaysKadet wrote: Thu Jul 16, 2026 6:53 pm After today's update, I can now see the BMP thumbnail and all the data on the label, and after tapping I can also see the image and additional
??When I look at the Gallery or any folder and, for example, I gives a filter for PNG files, I also see JXL and BMP files (I don't have any other types beyond the basic files).
EXIF/XMP yes, jpegxl not fully supported. but no thumbnail even with v18?information. For JXL I don't see a thumbnail and only information about the date, file name and size. After tapping I see the image, but still without the X/Y size and EXIF information.
Kadet
I wrote about v18. No thunbanail and info.xnview wrote: Sat Jul 18, 2026 12:09 pmok, but do you have alwaysKadet wrote: Thu Jul 16, 2026 6:53 pm After today's update, I can now see the BMP thumbnail and all the data on the label, and after tapping I can also see the image and additional??When I look at the Gallery or any folder and, for example, I gives a filter for PNG files, I also see JXL and BMP files (I don't have any other types beyond the basic files).
I added an AVIF file, and now when I filter on a PNG file, I see AVIF, JXL and BMP files too.
Edit: v19 buged too.
could you post a screenshot, please
You means when using 'Device memory' and not 'Gallery'?I added an AVIF file, and now when I filter on a PNG file, I see AVIF, JXL and BMP files too.
Kadet
This is screenshots from 'Gallery', 'TEST' from 'Bookmarks', and 'TEST' from 'Device memory' with some filters:
In Gallery, you can see jxl files?? Which android version?Kadet wrote: Thu Jul 23, 2026 8:09 pm This is screenshots from 'Gallery', 'TEST' from 'Bookmarks', and 'TEST' from 'Device memory' with some filters:
Kadet
Realme 12 Pro+ with realme UI 7.
Android 16 - RMX3840_16.0.5.7Q1 (EX01).
I must say that it seemed that I would not be of much help in testing the application, but here one puzzle follows another
please check v21
Kadet
It's getting better, but there's one more step to take. I added two QOI format files to the test folder and both are visible in filtered files after selecting 'Folders' and 'Device...'.
Please check v22Kadet wrote: Sat Jul 25, 2026 5:44 pm It's getting better, but there's one more step to take. I added two QOI format files to the test folder and both are visible in filtered files after selecting 'Folders' and 'Device...'.
