When selecting sorting by “Date taken”, the application first takes the date from EXIF. This has advantages, but when I tested “Convert”, new files did not appear at the top. Therefore, it would be good to add the “File create date” option.
It's similar to "Modified date". Here, however, I would simply use the file date rather than EXIF.
👍[v18] Setting Display Sort [work in v19]
Kadet
Re: [v18] Setting Display Sort
please check v19
