[Fixed] V1.0 (19) - JPEG XL compression - which effort is used? [Fixed]
masterjp
Post by masterjp »
I use XnView MP on Windows and there a many different compression settings for JPEG XL.
Do you have plans to add a slider for effort level = 0 to 9?
I did not often use the jpeg xl picture format on mobile or tablet,
because it costs much battery power for decoding and encoding.
That is the reason I prefer webp file format with a good balance of quality to filesize.
I am very suprised how fast jpeg xl files get compressed on mobile and tablet.
Which effort level is currently used?
Kadet
Re: V1.0 (19) - JPEG XL compression - which effort is used?
Post by Kadet »
My guess is 7. These few of my test conversions point to that. This is the default effort and seems very reasonable. On the phone, the conversion took about 1-2 seconds for typical photos. For the same photos on PC, setting effort 8 took 3-4 times longer.
masterjp
Post by masterjp »
Thank you. It is a good value for speed/compression effeciency.
