I converted a jpeg file with xnview mobile and choosed a destination folder on my device.
I grant xnview the read/write permission for the destination folder.
The conversion worked perfect.
After that, I converted a further file to the same destination directory.
I must grant the same permission for the same destination folder again.
Other apps save the permission and do not ask again.
Is it possible to improve this behaviour? Thank you.
[Fixed] V1.0 (19) - grant permission for folders every time I use the folder [Fixed]
masterjp
Re: V1.0 (19) - grant permission for folders every time I use the folder
which apps?masterjp wrote: Sat Jul 18, 2026 4:26 pm Other apps save the permission and do not ask again.
masterjp
I compare the grant permission with other gallery apps e.g. fossify gallery, piktures, ReFra from google playstore.
Solid explorer (filemanager) does it also user friendly.
Please check v22masterjp wrote: Sat Jul 18, 2026 4:26 pm Other apps save the permission and do not ask again.
masterjp
The new version 1.00 (22) works smooth and nice.
I did not see any further grant permission screen.
Great!
Great!
