XnView 11.1.5 [10164] (Deb) on Pop_OS! crashes while opening mp4
richie
Post by richie »
If you click on a MP4 file, the app crashes giving error:
0.35.1 (git 652c616) - Multimedia Development Kit. Copyright (c) 2016-2025 WangBin(QtAV author) <wbsecg1 at gmail.com>
Build for: pop/24.04 7.0.11-76070011-generic 4KB x86_64; glibc2.24/2.39 libc++220000; Clang22.0.0 (++20251222082052+3fac75ce8002-1~exp1~20251222082218.1367); 07:31:12 Dec 30 2025.
qt5ct: using qt5ct plugin
==> 1,000000 1,000000 143,907121 96,000000 (0)
XNVIEW restoreGeometry before : 640 480
XNVIEW restoreGeometry after : 1914 943
## MyDB::exec prepare failed (err=1): near "?": syntax error
query (first 200 chars): PRAGMA CACHE_SIZE=-?;
ARG[] = /opt/XnView/XnView
ARG[] = --version
BLOB length 75
## updateCount ===> 3ms (6)
## updateCount ===> 6ms (10)
## updateCount ===> 6ms (0)
## updateCount ===> 7ms
## updateCount ===> 7ms ok
qt.qpa.wayland: Wayland does not support QWindow::requestActivate()
X11 display: 0x58d157ccb300
QMDKWidget setMedia /home/user/Downloads/sample-5s.mp4
resizeGL>>>>>dpr: 1.000000, logical dpi: (96.000000,96.000000), phy dpi: (93.784615,94.593103)
Segmentation fault (core dumped)
Re: XnView 11.1.5 [10164] (Deb) on Pop_OS! crashes while opening mp4
do you have tried to set
QT_XCB_GL_INTEGRATION=xcb_egl
richie
Post by richie »
I tried it now with this variable exported but same issue.
and could you try the beta QT6
richie
Re: XnView 11.1.5 [10164] (Deb) on Pop_OS! crashes while opening mp4 [Solved]
Post by richie »
I tested it again with the actual release. Downloaded TGZ version. Now it works.
