How to use search to find files with file format error? (exiftool value) (bug?)
KB9
Post by KB9 »
Search all files with this error:
Not wotking:
Not wotking:
Not finding anything.
I few other as well ( exif all values) with File format error and error doesn'y find anything. Howto succeed?
jkm
Re: How to use search to find files with file format error? (exiftool value) (bug?)
Post by jkm »
Those are not actually tags, they are Exiftool diagnostic data. They are not searchable in XnViewMP. The field name you entered in the search dialog is invalid.
You can write a batch file or script if you want to directly test for exiftool errors.
KB9
Post by KB9 »
jkm wrote: Sat Jul 25, 2026 5:18 pm Those are not actually tags, they are Exiftool diagnostic data. They are not searchable in XnViewMP. The field name you entered in the search dialog is invalid.
Script for XnViewMP? Exiftool?
I don't want crawl files that has minor issues but still working. I noticed in some folders I have bunch of files that are
Exiftool: tag: Error
value: File System Error
KB9
Post by KB9 »
@echo off
setlocal
:: Set folders here (keep the quotes, do not add a trailing slash)
set "SOURCE_DIR=C:\path\folder"
set "DEST_DIR=C:\path\folder2"
echo Scanning for files with ExifTool errors...
echo Source: %SOURCE_DIR%
echo Destination: %DEST_DIR%
echo ---------------------------------------------------
:: The ExifTool command to find errors and move the files
:: -r means scanning sub folders of %SOURCE_DIR%: remove -r if sub folders not needed
exiftool -charset filename=utf8 -r -if "$error" -Directory="%DEST_DIR%" "%SOURCE_DIR%"
echo Scan and move complete!
pause
The above code found the files that I needed to remove - only produced "file system error" tagged files to destination dir where I checked the results and all were non-working files.
In Windows you need to have Exiftool.exe location (path) in Windows environment variables -> System variables -> path
(SystemPropertiesAdvanced.exe)
