In many gallery apps it is possible to see the camera folder (internal storage => DCIM => CAMERA) at position No. 1 in gallery view.
So you get a fast access to your camera pictures. In XnView I can set the camera folder as bookmark. This is okay, but a bit cumbersome.
I have many folders on my smartphone with pictures and use a 3x6 thumbnail screen in gallery.
My camera folder is somewhere on position 22 in my gallery.
Is it possible for you to sort the camera folder by default at position No. 1 or add a switch in settings?
That would be very useful.
[Fixed] V1.0 (21) - Option for camera folder at position #1 [Fixed]
masterjp
Re: V1.0 (21) - Option for camera folder at position #1
you have it in menu Camera/Download/Screenshot
masterjp
Yes, you are right.
