When using the default F6 to switch layouts, pressing F6 once while the browser window has an image in focus allows switching to the folder area and selecting the folder.
However, conversely, when selecting a folder within the folder area, it requires pressing F6 twice along with the arrow keys to select the first image.
The expectation is that pressing F6 once will select the first image. Is there a problem with cmd_switchPanel?
v1.11.5 There's an issue with switching layouts
alee001
alee001
Re: v1.11.5 There's an issue with switching layouts
Note: Repeatedly pressing F6 to switch panels will cause the app to crash.
cmd_switchPanel sets focus to folder view if focus was in thumbnails view, its the correct behavior
No crash here with default settings...alee001 wrote: Thu Jul 30, 2026 4:11 pm Note: Repeatedly pressing F6 to switch panels will cause the app to crash.
alee001
After I reinstalled, everything returned to normal.
