XnView: MP 1.11.5 - 64 bit
OS: Windows 11 25H2
I use GIMP to fix Some old images.
When I try to use the "clean all other markers" option (from the clean metadata function) the image file size increases
The image has no other metadata information.
I noted the same behaviour from files before I even edited them (right after I scanned the image.)
How can this be? shouldn't clean shrink the file (or at least keep it the same?)
Clean app markers increases the image file size
hor0124
Re: Clean app markers increases the image file size
Are you able to post example 'Before' and 'After' files for someone to inspect?
check your format write settings in Settings>Formats>Write
hor0124
Here is a simple example I created (don't be alarmed - it's a black rectangle).
check 'Optimize Huffman table'
hor0124
Thanks user0.
May I ask that you specify what the setting should be instead of just saying "check".
Some more examples
Before - Copy (2) is fresh out of Gimp 3.24.
After - Copy (2) is after "cleaning" with 'Optimize Huffman table' turned on.
Some more examples
there are 2 ways to remove metadata in XnViewMP
However, it looks like XnViewMP uses jpegtran (from libJPEG/turbo) which affects bitsteam,
if you want to strip all metadata w/o touching bitstream - use exiftool
Test
test with your 2nd example file (1.28 KiB)
- in Viewer
it only affects the loaded image, so the image must be saved (encoded) and Write settings will be used
- in Browser (your case)
it does not re-encode image, so the bitstream should theoretically remain identical
Test
- XnViewMP OR jpegtran
Browser>Metadata>Clean... - all checkboxes, except huffman optimization
4.97 KiB bitstream changed, APP0 remains
2.51 KiB bitstream changed, APP0 remains
- exiftool
1.26 KiB bitstream unchanged, all metadata removed
