Crash while doing batch convert
obelisk
Post by obelisk »
I'm using version 1.11.5 but this has also affected previous versions.
I select multiple JPEG files and then do a batch convert
  • Shrinks to a certain size and saves to an output.
Sometimes after converting the files the whole main window closes. There is no error or anything. It does not happen all the time but it happens maybe 50% of the time.
alee001
Re: Crash while doing batch convert
Post by alee001 »
Just passing by...
This problem has happened before, caused by incomplete or damaged images.
obelisk
Post by obelisk »
do you have more information? The files in question were created by evoto ai
they have no support whatsoever
alee001
Post by alee001 »
obelisk wrote: Thu Jul 30, 2026 6:17 am do you have more information? The files in question were created by evoto ai
Some images may appear complete, but when opened with other apps, they may be found to be unreadable or corrupted. Unless checked with a tool, they need to be repaired to return to normal.
do you have a way to reproduce?
obelisk
Post by obelisk »
no, I run convert several times on the same files to I'll put JPEG and different sizes and TIFF
sometimes the same files will crash and sometimes they will not
