1.11.5: DWG files with unicode filename shows only preview
jSerg
Post by jSerg »
Subject: 1.11.5: DWG files with unicode filename shows only preview
XnView: MP 1.11.5 64 bit
CADImage.dll 64 bit in /plugins
OS: Windows 11 64 bit 25h2
DWG file in attachment (unicode filename, additionally zipped) - XnView MP shows only preview/thumbnail.
But if rename it to ascii/english - all ok.
Effect: can't work with DWG files with unicode filenames.
1. Open attached `йц.DWG`
Actual behaviour (bug): XnView MP shows only preview/thumbnail. See comparison in `1.jpg`
Expected behaviour: Show full picture
Re: 1.11.5: DWG files with unicode filename shows only preview
currently the CADImage support only non unicode filename
jSerg
Post by jSerg »
CadSoftTools support says that CadImage.dll supports Unicode file names.
As an option - is it possible to temporarily rename the file (implicit)?
This problem is supposed to be fixed in XnView MP 1.11.6. Please check and confirm the bug fix here.
