XnView: MP 1.11.5 - 64 bit
OS: Windows 64bit
When opened with XnViewMP 1.11.1 and newer, some of the images display blotches of orange color on what, I assume, should be white.
1. Open the attached sample.png file using XnView 1.10.5
2. Take note (or a screenshot) of what it looks like.
3. Open the attached sample .png file using XnView 1.11.1 through 1.11.5
4. Take note (or a screenshot) of what it looks like.
Actual behaviour (bug):
- When opened with 1.11.1 through 1.11.5, the rounded square is orange
Expected behaviour: The rounded square is white
Some whites became orange in 1.11.1 onwards
ChuckleTed
Re: Some whites became orange in 1.11.1 onwards
press J to disable Clipping warning
ChuckleTed
May I suggest having it disabled by default?
It may be confusing (like it was for me in this case) when the user is not aware of it.
it will reset to disabled state after a restart in the next version
related
Clipping warning - color scheme, color modes
related
