OS: Windows 64bit
The "Enhance colors" dialog (opened using Shift-E by default) has drastically changed/broke the way it works between versions 1.8.0 and 1.8.1
Effect: Adjusting Brightness and Contrast has little to no effect until the slider reaches around +50.
1. Open any image using XnViewMP 1.8.0
2. Open the 'Enhance colors' dialog and play with the Brightness/Contrast sliders.
3. Note (or screenshot) how they affect the image at different settings.
1. Open any image using XnViewMP 1.8.1 or newer.
Actual behaviour (bug): The sliders barely affect the image until about halfway through (+50)
Expected behaviour: There is a noticeable effect on the image at every step in the adjustment.
See attached screenshots:
