I tested the show info switch in slideshow menu.
I see a small "--x-" text with a black transparent background in the left lower corner of the screen.
I expected to see the same text of the fullscreen view. (e.g. filename, date, etc.).
Another thing which is disturbing, that the info text is jumping, if I touch the screen to see the three playback control buttons.
v24 - slideshow - show info is missing - text position jump if screen is touched
masterjp
Re: v24 - slideshow - show info is missing - text position jump if screen is touched
do you have enable the setting to show information?masterjp wrote: Sun Aug 02, 2026 8:05 pm I tested the show info switch in slideshow menu.
Kadet
There was a bug in version v24. Now in v25 it has improved.
From the information I set, now I don't see only {exif:exposoureTime}
masterjp
You have fixed the jumping overlay info text. Thank you.
