👍[v24] Thumbnail's labels stopped showing [Fixed]
Kadet
Information on Thumbnail's labels stopped showing. I only see empty space. But when I add something to the metadata, the data indicated in the settings appear under this image.
Re: [v24] Thumbnail's labels stopped showing
sinve v24? even if you reinstall the app? Which labels do you use? in gallery or folder view?
Please check v25
Kadet
Thank you! Works now.
