Is it perhaps possible to set the transition so that the same transition effect doesn't repeat twice?
I saw the same transition effect two or three times in random mode.
I imagine it working like this: XnView remembers the last type of transition. When the random generator selects a new effect, it compares it to the previous one. Then, if there are repetitions, the random generator would keep trying until the effect is different.
v24 - slideshow random transition - sometimes repeat same transition multiple times [Fixed]
masterjp
masterjp
Re: v24 - slideshow random transition - sometimes repeat same transition multiple times
Wow, you are very fast. Thank you so much. It is much better than before.
