[v26] incorrect lossless encoding
Kadet
Post by Kadet »
On XnPC, converting jpg to png gives the same CRC in pixel-level file comparison (Shift-C). The same file converted to png on XnMOBI gives a different CRC. After enlarging it, I can't visually notice the difference, but there must be a difference since there is a different CRC.
Re: [v26] incorrect lossless encoding
Please send me the original file and the one converted by XnView & XnMobile?
Kadet
Post by Kadet »
xnview wrote: Tue Aug 04, 2026 5:53 am Please send me the original file and the one converted by XnView & XnMobile?
https://drive.google.com/file/d/1ahUyaS ... sp=sharing
i've check on XnView, and the CRC is different between original.jpg & xnview.png
Kadet
Post by Kadet »
Hmm. It's my:
I set read the JPG files method as Floating-point (if it makes any difference).
In my opinion, this is the right behavior to keep the CRC the same. Of course, it is true if the same JPG decoding method is used to covert and to compare.
Kadet
Post by Kadet »
Kadet wrote: Wed Aug 05, 2026 12:56 pm I set read the JPG files method as Floating-point (if it makes any difference).
When I changed this setting now I have different CRC in compared function XnView on Windows.
This seems to explain everything. One method should be used to read (and encode?) JPG files. For me it should be Floating-point. Nowadays computers are so fast that others don't matter.
ok, now i understand. I've added settings for JPEG
Please check v28
Kadet
Post by Kadet »
I set JPG reading to FP, but the CRC still does not match. It does not match any DCT reading method in XnPC at all.
Kadet wrote: Thu Aug 06, 2026 7:37 pm I set JPG reading to FP, but the CRC still does not match. It does not match any DCT reading method in XnPC at all.
After some search, on ARM you can't get same CRC using 'float' as intel x64.
