Since the first time I used XnView mobile I did not use the rating feature in your app.
It always indicate (1) entry, but all of my files do not have a rating.
In rating menu there is only a single folder of unrated pictures.
Is it possible to indicate it with (0)?
v26 - rating - always one entry (Fixed)
masterjp
Re: v26 - rating - always one entry
sorry but i don't understand?
masterjp
The rating menu always say (1) is rated, but there are no rated files. All files are unrated.
Please check v28
Kadet
For me at the moment, "Ratings" shows the correct number of files rated.
masterjp
Rating is correct now for zero files rated. Thank you!
