I tested the rating feature and rated some pictures. I can choose a rating of 1 to 5, but it is impossile to unrate a picture.
I would like to see a function to remove it. Thank you.
Furthermore it would be very fast and nice, if it is possible to choose the rating level by swiping left or right over the stars.
Of course, that would be pure luxury when it comes to control.
v26 - rating - it is impossible to unrate a picture [Fixed]
masterjp
Re: v26 - rating - it is impossible to unrate a picture
if you tap on the current rating, it will remove it
masterjp
Thanks for explaining how it works.
It works well. That's actually enough. Thanks!
