v26 - rating menu - unrated pictures - deleting of pictures does not work [Fixed]
masterjp
Post by masterjp »
I tried to delete a single jpegxl picture file from unrated folder within the rating menu.
The delete dialog appear, but move to trash and delete permanently do not work.
Re: v26 - rating menu - unrated pictures - deleting of pictures does not work
is it working on jpeg/png?
masterjp
Post by masterjp »
Deleting JPEG or PNG files works without any problems. :)
Please check v28
masterjp
Post by masterjp »
Sorry for my poor description of this issue. :( I have only just realized the actual cause of the problem! :)
The rated picture file in the rating section doesn't display a preview image.
I can't delete it because the file no longer exists :!:
I had already deleted it in an android file manager app.
That's why deleting it in the rating section doesn't work.
I hope you can insert a check procedure, which automatically remove all missing files in rating section.
masterjp wrote: Fri Aug 07, 2026 10:26 am I hope you can insert a check procedure, which automatically remove all missing files in rating section.
"pull down to refresh"?
masterjp
Post by masterjp »
Yes, this would be good!
masterjp wrote: Fri Aug 07, 2026 3:07 pm Yes, this would be good!
Please check v33
masterjp
Re: v26 - rating menu - unrated pictures - deleting of pictures does not work [Fixed]
Post by masterjp »
Thank you! :)
