Configuring "Import and sort" dialog (File > Import...) can be error prone, notably "Subfolder" and "New filename" fields.
The first one has its preview, the second one no... User has to begin the copy/move operation to notice that something is wrong... then stop the command and use batch rename.... then apply Import and sort again....
Please consider adding a preview to the "New filename" field, as the one one for "Subfolder"
Thanks for listening.
XnViewMP 1.11.5 win11
Feature request: Import and sort preview for "New filename" field
Gwenael Q.
