Save Resolution of Images
More Multi Platform Tools - Windows, MacOSX, Linux
Frodo
Post by Frodo »
I'm running XnView Sketch (v1.18). I'd like to know if there is a way to save images processed with XnView at higher resolution. When I use a high res image in the program and save the result, XnView saves it at an absolutely low-res trash resolution. I can't find any settings on the app at all to fix this. Are the controls hidden somewhere?
jkm
Re: Save Resolution of Images
Post by jkm »
Welcome to the forums...
1. Please post XnSketch questions in the board for that product, not here in the XnViewMP board. You'll find it here.
2. The save settings are in the toolbar button. The folder with a green arrow going into it is the save button. On its right, there is a little down-arrow menu. Click the down-arrow menu to get the save settings. Choose "Original" for the full resolution of your source image.
Hopefully this helps.
