It is not friendly in CN default situation.
it can be set to system default(MS YaHei UI) or let users customize,
Pls don't hard-coding fonts in the tabs
ziotean
Re: Pls don't hard-coding fonts in the tabs
Qt uses system font, please check if it's different with Qt6 beta
ziotean
I found qt6 version and downloaded and checked , qt6 version is ok ,thank you.
I m testing what you said in the thread and will report (if there is any thing can help)
