MP43 Files
XmSurfer
MP43 Files
Post by XmSurfer »
I have a bit of a wierd problem. In 1.82-RC3 I was able to get thumbnails for all of my video files. But in 1.82-Final, when dealing with some old MP43 encoded files, the thumbnails are generated from only the first frame of the video. This is only really a problem on files that fade in from black since I get a video thumbnail that is all black. I do not have this problem with newer videos encoded in Xvid, WMV1,2,3, or MPEGs. I have tried reinstalling the final release and using different decoders for MP43 but the thumbnails are still from the first frame of the video. I reinstalled 1.82-RC3 and the video thumbnails for MP43 encoded files are created normally. Is anybody else having this problem?
Dreamer
Post by Dreamer »
I have the same problem with MOV files, but it's a known 'bug'.
n… frame option ?
:arrow: Dreamer
:) Hello !
- IIRC, this has been discussed a while ago, and some users proposed an option to display the n…th. frame as the thumb-nail… ?
- I guess it could be the solution, and maybe could you notice that for your "bugs" thread, for the 1.83 ? :D
:mrgreen: KR
Dreamer
Re: n… frame option ?
Post by Dreamer »
Clo wrote:- IIRC, this has been discussed a while ago, and some users proposed an option to display the n…th. frame as the thumb-nail… ?
It's already working, almost for all formats, except MOV and probably MP43.
XmSurfer
Post by XmSurfer »
The funny thing is that it works for MP43 encoded files in 1.82-RC3 but not 1.82-Final.
I said : OPTION
:arrow: Dreamer
:) This is quite lame, because here in 1.82 final :
1. *.avi and *.mpg work,
2. *.wmv does not work, only the associated progamme icon as thumb-nail,
3. I found out only one *.mov in my usual PC, but it doesn't work at all, moreover I've not any "Quick Time' and don't wish to install one.
4. I said above an Option - thus, a certain user-configurable amount of frames to ignore before to catch one and set it as the thumb-nail…
- But I don't see such an option, even among some new (rare) extra INI-entries; aside, it could be set such as, as well…
- Obviously, supposing that the feature skips a pre-defined hard-coded amount of frames from the file head, this is not suitable in all cases…
:arrow: XmSurfer
:? Yep ! I have a few videos only, and not any MP43… You touched an interesting point. I would be glad to get one in order to test and fill my "Samples" folder a bit more… ;)
:mrgreen: Kind regards to All,
Re: MP43 Files
XmSurfer wrote:I have a bit of a wierd problem. In 1.82-RC3 I was able to get thumbnails for all of my video files. But in 1.82-Final, when dealing with some old MP43 encoded files, the thumbnails are generated from only the first frame of the video. This is only really a problem on files that fade in from black since I get a video thumbnail that is all black. I do not have this problem with newer videos encoded in Xvid, WMV1,2,3, or MPEGs. I have tried reinstalling the final release and using different decoders for MP43 but the thumbnails are still from the first frame of the video. I reinstalled 1.82-RC3 and the video thumbnails for MP43 encoded files are created normally. Is anybody else having this problem?
Could you send a sample?
Dreamer
Post by Dreamer »
Works good here.
Re: MP43 Files
Post by Guest »
xnview wrote:Could you send a sample?
I have no idea how I could do that. How would I go about providing you with a sample?
XmSurfer
Post by XmSurfer »
Sorry about the "Guest" posting. I thought I was logged in.
Re: MP43 Files
Could you send me a sample at [email protected] (remove -nospam)
XmSurfer
Re: MP43 Files
Post by XmSurfer »
xnview wrote:Could you send me a sample at [email protected] (remove -nospam)
Sent
