Various elements are too small compared to other/native windows on recent Fedora Gnome. It's a 4k display and resolution set to 150% zoom in the Gnome display options.
Stuff like: titlebar, folder icons in the tree view and "compare" view, the whole "save as…" dialog from the viewer, … probably more.
v1.11.5 on Fedora/Gnome doesn't scale the GUI properly
Danny
Get the bugs fixed, THEN start adding features. It sucks, but someone has to do it.
Re: v1.11.5 on Fedora/Gnome doesn't scale the GUI properly
it's a known issue, please check the beta Qt6
Danny
That one works. Cheers.
Hopefully it will work with the Flatpak release, too.
