v32 - Renaming dialog - add current and parent Folders [fixed]
B.Douille
Post by B.Douille »
Can we add the name of the folder (Album) as well as the parent folder ?
Can we also add an underscore between date and time (or a mean to edit the date/tome format) ?
Thks in advance
Daniel, happy user for 20 years, to manage photo and videos and share them in slideshows (Windows 11, Linux Ubuntu and Android)
Re: v32 - Renaming dialog - add current and parent Folders
B.Douille wrote: Sun Aug 09, 2026 12:53 am Can we add the name of the folder (Album) as well as the parent folder ?
So Album (gallery view) or Parent folder (disk view) as third line?
yes by default, and you can change it
{date[yyyy]}
{date[yyyyMMdd}
B.Douille
Post by B.Douille »
xnview wrote: Sun Aug 09, 2026 8:22 am
Both if possible but Album is the main one.
Sometime the parent folder can be used as a general subject (location of a travel for example) while the folder (Album) as the topic monument, fun place, city,...)
please check v36
B.Douille
Post by B.Douille »
Good !
Going to change my mobile workflow :D
B.Douille
Re: v32 - Renaming dialog - add current and parent Folders [fixed]
Post by B.Douille »
Oups, back to the list of To do.
Either I missed the thing when I tested or there was a regression in between?
In the list of items available to renaming the File category there is Parent Folder, which is right and works fine. However the Current folder (== Album) is missing.
B.Douille wrote: Wed Sep 09, 2026 10:36 am In the list of items available to renaming the File category there is Parent Folder, which is right and works fine. However the Current folder (== Album) is missing.
In File tab, you have album as first item
B.Douille
Post by B.Douille »
You are right Pierre, I missed it. And having a look at the thumbnail labels I found the same "issue", didn't catch the Album item and was close to tell :|
Wouldn't it be better to name it "Folder (Album)" or "Album (folder)" ?
B.Douille wrote: Wed Sep 09, 2026 1:22 pm Wouldn't it be better to name it "Folder (Album)" or "Album (folder)" ?
The problem is the name??
B.Douille
Post by B.Douille »
Or my glasses :)
If you can change the name, yes
