v34 - info overlay text - long names for exif-data [Fixed]
masterjp
Post by masterjp »
Today I tested the different info overlay text placeholders for different exif datas.
Many of the placeholders begin with "EXIF:," even though we are already in the EXIF section and the remaining words are not used twice.
So It might therefore be clearer and easier to find if the word "EXIF:" were omitted.
Re: v34 - info overlay text - long names for exif-data
please check v36
masterjp
Post by masterjp »
The way the EXIF placeholders are abbreviated is well done! Now more words are visible. What surprises me in landscape view is that the terms are sometimes distributed differently. For example, the first line has 4 words, and there’s still plenty of space left after that. In contrast, the second and third line is completely full of words. In theory, with a better distribution, all the words would appear on the screen. (Tested on a smartphone)
Another problem with the Info overlay text editing menu is the landscape view. If the samsung keyboard appears the whole input field will be overlapped by the keyboard. I use the keyboard with standard size. I think google keyboard is not smaller.
Is it possible to make the editing of the text more comfortable? In landscape view it is important to see at least one input line.
Please check v39
masterjp
Post by masterjp »
Great! It is better now. Thank you!
