On my Android TV Box with Android 11 (screensize 1920 x 1080 pixels) there are some graphic glitches on the slider for png compression.
On other devices (smartphone and tablet) I did not see this problem.
The slider position dynamically change or do an graphic refresh by itselfs.
V34 - Settings - conversion menu - png compression slider move automatically [Fixed]
masterjp
masterjp
Re: V34 - Settings - conversion menu - png compression slider move automatically
ou changed the conversion screen, and now all sliders work correctly. Thank you!
During testing, I noticed another problem.
On the Android TV box, the conversion menu ends with the setting for Filter – All (automatic).
I do not see the additional settings for WebP compression, filter strength, and filter sharpness.
I tried navigating with my Android remote control (using the up and down arrows).
The navigation works fine in the other menus.
please check v37masterjp wrote: Wed Aug 12, 2026 2:53 pm During testing, I noticed another problem.
masterjp
Yes, you have fixed it. Thank you!
