Clipboard Input Not Working (v7.300)
beornlake
Post by beornlake »
It seems that v7.300 breaks Clipboard input. My scripts are working fine on v7.230, but on v7.300, nconvert just fails to process anything.
I noticed that on v7.230, it reports the following when the script completes, but this line is not present when running v7.300:
Conversion of clipboard into output.png OK
(This is on Windows 11 25H2).
Thanks!
Re: Clipboard Input Not Working (v7.300)
right will be fixed
beornlake
Post by beornlake »
Wonderful, thank you!
beornlake wrote: Fri Aug 14, 2026 2:45 am Wonderful, thank you!
Please try the 7.301
beornlake
Post by beornlake »
Finally got around to checking this, and can confirm that 7.301 resolves the Clipboard issue. Much appreciated!
