Order of terms in NConvert code
While as far as I know it has never been formally documented, I have long understood that in NConvert code the input files to be processed must be last (right-most) term. That was the position shown in Helmut's posts outlining NConvert use after the utility was introduced, the order of terms I have always followed successfully, and was recently indicated by Pierre when replying to a post regarding code that didn't run.
However, replies to a post today concerning the -clip option seem to suggest that order of terms wasn't applicable, so could Pierre please make a general statement regarding the correct order of terms in NConvert code? :D
Note: it's too hot here to put in the links, but if someone cares to PM them to me I will endeavour to insert them!
Re: Order of terms in NConvert code
any combination works for me (in 7.230)
nconvert.exe  -clipboard  -grey 256  -out clipboard
nconvert.exe  -clipboard  -out clipboard  -grey 256
nconvert.exe  -out clipboard  -clipboard  -grey 256
nconvert.exe  -out clipboard  -grey 256  -clipboard
nconvert.exe  -grey 256  -clipboard  -out clipboard
nconvert.exe  -grey 256  -out clipboard  -clipboard
user0 wrote: Thu Aug 13, 2026 6:14 pm any combination works for me (in 7.230)
...in relation to -clip, but there remain reasons for wondering if that might be an exception to a general rule that input terms must be last, particularly as I recall Pierre recently stating that a poster's code didn't run as that the input term needed to be las! :?:
A statement from Pierre would be welcome, given the above, in the absence of significantly more detailed testing.
