How to put a custom "Open With" button directly into the menu bar
dieters
Post by dieters »
Hey, I have a custom "Open With", which can be called with "Alt+1".
I want to have a button in the menu bar that directly calls it.
At the moment, I have to click the "Open With" button and then select the option.
I tried to use the --COMMAND-- option, but that does not give the same result, if the image has been altered and not saved.
The --COMMAND-- option passes the original filename as a parameter.
However, "Open With" passes the temporary filename as a parameter.
I need the temporary filename or, if possible, both filenames as parameters.
Does anyone have an idea how this can be realized?
Re: How to put an Csutom OpenWith directly as Button in the Menubar
You might check your spelling throughout, multiple inconsistencies... :wink:
You wish to create a custom 'OpenWith' shortcut?
dieters
Re: How to put a custom "Open With" button directly into the menu bar
Post by dieters »
Yes, sorry, English is not my native language. I tried to fix it.
If there is an option, to implement it in XNView classic, that would also help.
