I wonder if i can change the "associated editor" with an other program then mspaint, so it can be opened by pressing the F4 key?
I searched the forum, and found a few threads about it, but i am still a bit confused if it can, or can not be done?
Someone wrote; it's easy, ... just GOOGLE for it, ... but i cant find what i am looking for!
For instance, where is the association made for mspaint.exe to be the default editor?
Is this done by XNview, or WindowsXP, if so, can this be changed?
Thanks in advance, hope someone can help me out here
GRTZ John
F4 Associated editor issue
Re: F4 Associated editor issue
You must change it in windows explorer associations...nhojnavslig wrote:Hello,
GRTZ John
ckit
Add your support here -> http://newsgroup.xnview.com/viewtopic.p ... ted+editornhojnavslig wrote:Hello,
GRTZ John
ckit
Pierre, when a user presses F4 for default editor what registry key does XnView read?
Thanks.
Update:
Nevermind I just "Regmon" to check how XnView uses and was horrified beyond words (how many unknown references?)
Anyway I found the fix for adding your own default editor...
1. Open RegEdit
2. Goto HKEY_CLASSES_ROOT\XnView.jpg\shell
3. On the "shell" branch, right-click "New" -> "Key"
4. Call it "edit", click on "edit" -> right-click "New" -> "Key"
5. Call it "command" click on "command"
6. In the opposite window -> double-click on the (Default) and enter your editor path (eg. "C:\Program Files\PhotoFiltre\PhotoFiltre.exe" "%1")
Sadly, this only works for one file type at a time!
I'll try and make a REG file for the common types using PhotoFiltre.
Thanks.
Update:
1. Open RegEdit
ckit
Ok to make this easier you can "cut and paste" this into a REG file using Notepad and then replace PhotoFiltre with your own editor after that all you have to do is right-click on the file -> Merge!
-- begin cut and paste --
REGEDIT4
[HKEY_CLASSES_ROOT\XnView.bmp\shell\edit]
[HKEY_CLASSES_ROOT\XnView.bmp\shell\edit\command]
@="\"C:\\Program Files\\PhotoFiltre\\PhotoFiltre.exe\" \"%1\""
[HKEY_CLASSES_ROOT\XnView.emf\shell\edit]
[HKEY_CLASSES_ROOT\XnView.emf\shell\edit\command]
[HKEY_CLASSES_ROOT\XnView.gif\shell\edit]
[HKEY_CLASSES_ROOT\XnView.gif\shell\edit\command]
[HKEY_CLASSES_ROOT\XnView.iff\shell\edit]
[HKEY_CLASSES_ROOT\XnView.iff\shell\edit\command]
[HKEY_CLASSES_ROOT\XnView.jp2\shell\edit]
[HKEY_CLASSES_ROOT\XnView.jp2\shell\edit\command]
[HKEY_CLASSES_ROOT\XnView.jpg\shell\edit]
[HKEY_CLASSES_ROOT\XnView.jpg\shell\edit\command]
[HKEY_CLASSES_ROOT\XnView.pcx\shell\edit]
[HKEY_CLASSES_ROOT\XnView.pcx\shell\edit\command]
[HKEY_CLASSES_ROOT\XnView.pic\shell\edit]
[HKEY_CLASSES_ROOT\XnView.pic\shell\edit\command]
[HKEY_CLASSES_ROOT\XnView.png\shell\edit]
[HKEY_CLASSES_ROOT\XnView.png\shell\edit\command]
[HKEY_CLASSES_ROOT\XnView.tga\shell\edit]
[HKEY_CLASSES_ROOT\XnView.tga\shell\edit\command]
[HKEY_CLASSES_ROOT\XnView.tif\shell\edit]
[HKEY_CLASSES_ROOT\XnView.tif\shell\edit\command]
[HKEY_CLASSES_ROOT\XnView.wmf\shell\edit]
[HKEY_CLASSES_ROOT\XnView.wmf\shell\edit\command]
-- end cut and paste --
REGEDIT4
ckv
XnView file association manager made by ckv (screenshot)
It's not ready to release yet.
This is not a joke
This is not a joke
ckit
ckv
It's on on the planning table.ckit wrote:ckv,
Does that include adding "Edit" entries into the registry as well?
BTW, Thanks!
Edit: new screenshot XnView file association manager made by ckv
nhojnavslig
