1.11.5: File sort is not saved in Join images
yudhi717
Post by yudhi717 »
XnView: MP 1.11.5 - 64-bit
OS: Windows 11 - 64-bit
After updating from 1.11.2 to 1.11.5
Files sorting is not saved in the join images
the sort header is saved but the image list is not sorted when join dialog opened
1. Select some image.
2. Select Create -> Join images.
3. Change the file sort, e.g by Name Desc
4. Click OK or Cancel.
5. Select some images again
6. The file sort header is saved correctly but the file list / thumbnail is not sorted
Actual behaviour (bug): join images file list / thumbnail is not sorted
Expected behaviour: file list / thumbnail should be sorted with previous setting.
