XnConvert 1.116
XnConvert 1.116
XnConvert (XnView batch convert as multi-platform standalone program) is available.
You can download XnConvert here
Windows x64 Setup
Windows x64 ZIP
MacOSX x64 DMG
Linux x64 TGZ
Linux x64 DEB
Linux x64 AppImage
Linux x64 Flatpak
MacOS APP Store
SHA256 CHECKSUMS
You can use
XnConvert file1 file3 file3
or
XnConvert @filelist
LyzaArc
Re: XnConvert 1.116
Post by LyzaArc »
New version completely remove JPEG-XL on Linux. Atleast in Flatpak via Flathub :( :(
PD: I love this program
Re: XnConvert 1.116
LyzaArc wrote: Wed Sep 30, 2026 11:54 pm New version completely remove JPEG-XL on Linux. Atleast in Flatpak via Flathub :( :(
right, a 1.117 comes
marsa
Re: XnConvert 1.116
Post by marsa »
Hi, I just wanted to mention a small problem (maybe a bug) that was introduced with 1.116.
On previous versions (including 1.115) I was able to remove selected files from the file list with the keyboard key "Del". Basically the keyboard key mimics the " - Remove" button above the file list.
On 1.116 the "Del" key doesn't do anything.
Re: XnConvert 1.116
marsa wrote: Thu Oct 01, 2026 5:45 pm On 1.116 the "Del" key doesn't do anything.
right :bugconfirmed:
