I wanted to copy or move picture files (*.jpg) from device memory (documents folder) to the hidden picture\.thumbnails folder.
I actived the show hidden files folder switch in settings menu. I can see the folder in device memory view,
but the move or copy dialog do not let me choose the hidden folder for destination folder.
[v48] - move/copy to hidden folder does not work [Fixed]
masterjp
B.Douille
Re: [v48] - move/copy to hidden folder does not work
I don't know what prevents such action but anyway I don't think this is a good idea to move, save pictures or modify existing thumbnail in this folder.
There are many .Thumbnails folder in the structure and it’s all for system/app usage. Touching them leads to unpredictable results.
Daniel, happy user for 20 years, to manage photo and videos and share them in slideshows (Windows 11, Linux Ubuntu and Android)
Please check v49
do you have always this problem?
could you tell me if its fixed?masterjp wrote: Thu Aug 27, 2026 7:27 pm I wanted to copy or move picture files (*.jpg) from device memory (documents folder) to the hidden picture\.thumbnails folder.
masterjp
The Problem is solved.
