[-v48] Action bar bug
Kadet
For many versions I have had it from time to time so that the lower action bar goes into the Android system bar. Unfortunately, I can't find a rule for this.
Re: [-v48] Action bar bug
Please check v49
Kadet
I need more time to evaluate this fix. For now, after several attempts, this bug does not appear.
do you have always this problem?
Kadet
Not yet, so let's consider it fixed. And when it returns, I will inform you about it.
