I cannot copy from the clipboard and then past the image into XNView. I need to first copy the image to Explorer and then drag it to the Main Pane of XNViewMP where you see the thumbnails.
My setup has the folder tree on the left and the thumbnail views on the right. I've been having this problem since at least v1.93 and am experiencing it on two different Win11 machines. I just updated to 1.11.6 and still have this issue.
Cannot copy - paste into thumbnail view
jkm
Re: Cannot copy - paste into thumbnail view
Pasting images into the XnViewMP browser works fine for me (Ctrl-C, Ctrl-V). I can copy from Windows Explorer and paste into the XnViewMP Browser, or I can copy from one Folder in XnViewMP to another.
You might want to check exactly what you're putting in the clipboard. To paste into the XnViewMP browser, it must be an actual file, not merely image data (pixels).
ebergerxn
I see what you mean, if I copy a jpg I can paste it into the thumbnail view. And if I have received an email in Thunderbird with attached jpgs I can also drag them to the thumbnail view. Furthermore, if the email has an embedded image and I right click it and select copy, to put it in the clipboard, I can then right click in my file manager (Directory Opus) and paste it into a folder as a jpg.
However, I now realize that Explorer does not support that operation (pasting an image from Clipboard) which is also what happens in XnViewMP. Is there a reason why XnViewMP should not support the type of image handling capability that Directory Opus handles to nicely?
So I guess this should be moved from a bug to a request?
jkm
This is not a bug.
The answer to your question is not clear, because imprecise terminology is muddying the issue.
Explorer DOES allow pasting an image from the clipboard, when there is an image file on the clipboard. But if you just have some bitmap data, a bunch of pixels, on the clipboard, that is "image data", not "an image file". It is not a file, and cannot be pasted as such. Explorer moves/deletes/renames/copies/pastes/etc files, not arbitrary bits of data.
I don't know what Directory Opus does and doesn't do. I haven't touched it in about 20 years.
It sounds like you're saying that if you have some arbitrary pixel data in the clipboard, and do a paste in Directory Opus, it says "Oh, I should invent and create a new file to hold this, and write it to the file system". Does it automatically select a file format (jpeg, bmp, png, tiff) as well and re-encode the image data if necessary? Does it invent a file name for you, or does it make you type one in? If you just have some text that you copied out of MS-Word on the clipboard and paste it in Directory Opus, does it create a new file to receive the text?
Most apps don't don't do that. You might look at an article on how the Windows clipboard actually works to better understand why.
If I'm misunderstanding you, "pasting an image from Clipboard" is too vague. You can describe exactly what you're doing (the steps) from beginning to end, or record a video of you doing it, where it "doesn't work" in XnViewMP. But that probably won't get you what you want...
Cheers...
Pasting "an image"? That does that mean?ebergerxn wrote: Tue Sep 01, 2026 7:13 pm However, I now realize that Explorer does not support that operation (pasting an image from Clipboard)
Cheers...
ebergerxn
I'm suspecting I can't get the feature I would like in XN, but let me try to describe it more clearly.
If I have an embedded image in a TBird email, an easy way to copy it is to either right click on it and select copy image, or to use SnagIt and to copy the portion of my screen that contains the image. Using the first method I can then paste it to a folder in Directory Opus and it creates a file labeled Clipboard Image.jpg. That opens as a jpg or can be dragged to XN as a jpg. Likewise if I tell SnagIt to copy the captured image to the clipboard it works the same way. I can paste it in Opus and it shows up as Clipboard Image.jpg. So both of these methods allow copying from the clipboard to Opus but neither of them allows copying from the clipboard to Explorer or XNView.
I guess Opus has some "smarts" that allows this.
By the way, you really should try Opus - it is a fabulous program and light years ahead of Explorer.
Thank you.
Thank you.
jkm
Ok, yes I understand exactly what you mean.
When you perform that particular action in Thunderbird (you might also have the option to save the image as a file), or when you use SnagIt, those applications do the same thing: they are placing a bitmap on the clipboard, nothing more. So it's not a file, and cannot be pasted as such.
But as I guessed before, Directory Opus is automagically taking whatever you have on the clipboard, inventing the necessary details (like a filename) and converts it to a file and saves it for you. Like I said, most apps don't do this, and don't hold your breath waiting for it to be added to XnViewMP.
However, an FYI regarding something that you said before:
You noticed that you can drag and drop an attached image file from Thunderbird to XnViewMP: that is standard and to be expected...
But actually, you should be able to drag and drop any image from Thunderbird, whether it is attached or not (like an inline embedded image from a remote URL). I tested this and when you drag a non-attached image from a Thunderbird email to XnViewMP, Thunderbird automatically packages the image as a file to facilitate the drag and drop, in the same way it would if you right clicked on the inline image (not the attachment icon) and selected "save image as". I tested this and it works fine. The an image file just appears in XnViewMP wherever you drop it.
So that would probably be the simplest way to get images from Thunderbird to XnViewMP. No clipboard or Directory Opus necessary...
But that sort of functionality is dependent on the sending application, known as the "source", Thunderbird in this case. If you tried that same trick with an image from some other email client or application, still dropping it in XnViewMP, it might not work.
So the next time you want to get any image out of Thunderbird, instead of using the clipboard or SnagIt, try to just drag and drop it.
Hopefully this helps...
Although it might not seem obvious from an end user perspective, the clipboard and drag-and-drop are totally different mechanisms for data interchange; for drag and drop, both the source and target application must be open and participate (whereas the clipboard is simpler, passive, and works even if the original application is closed). Thunderbird's drag and drop support is somewhat more robust than how it handles the clipboard.ebergerxn wrote: Tue Sep 01, 2026 7:13 pm if I have received an email in Thunderbird with attached jpgs I can also drag them to the thumbnail view.
