[v50] AC-3 not supported
Kadet
Video not support AC-3 codec.
Re: [v50] AC-3 not supported
Please send me a sample file? Currently the default video component is used, so it depends on android
Kadet
https://drive.google.com/file/d/1IIMDhr ... drive_linkxnview wrote: Sat Sep 05, 2026 5:58 am Please send me a sample file? Currently the default video component is used, so it depends on android
it works here, so i think that it depends on android version
are you able to play it with default app?
