Currently, the video player is suitable for watching video clips and other short videos.
I don't know if you want to improve the movie player to make it more pleasant to use, because if so, I suggest:
— This (i) icon should disappear after a few seconds and only reappear after a single tap, like other icons. Or don't show on start.
— When I click info, then when I come back to the movie, I would like to go back to the frozen frame and not watch the movie from the beginning.
— After exiting the video and returning to it, the video should start from the dropped frame.
XnMobi movie suport
Re: XnMobi movie suport
Please check v52
Kadet
The first two things work well. The third one doesn't work.
in fullscreen, you play a video file. You swipe up to go to detail and tap to returns in fullscreen. The video is not on same frame?
Kadet
The third point is something else. It's about a swipe down gesture or killing the app while watching. After something like this, the film starts from the beginning, and it would be good if it started from the interrupted moment.
