Hi! I'd love to select 2 images, then right click -> Slider Compare. It'd be awesome to have it in Windows Explorer as well.
Thank you
Comparison Utility with slider
xnrv
Re: Comparison Utility with slider
Its coming to Photoshop, but I still would prefer XnView (because of opening times)
https://youtu.be/ZWosWnbi6X8?si=QTGS7do8NEXPr8ue&t=32
@0:39
@0:39
1. open Browser tab
2. select 2 images of the same size
3. press Shift+C to open Compare
4. select A/B mode
4. select A/B mode
KLE-France
Let's say "make it more flexible" instead?
That the two images have to be—exactly— the same size greatly diminishes the usefulness of this function.
Sure, I can look at, say, two differently developed versions of a same image, and that's great...as long as I haven't cropped one.
The A/B function is a good start, but I too think it could be better.
So, I would simply re-word xnrv's title as "Make the A/B comparison utility more flexible".
xnrv
great tip, thank you!user0 wrote: Thu Sep 10, 2026 9:19 am 1. open Browser tab
4. select A/B mode
